PeterDs said:Do you mean I had to change the Audio input and output figuresin the Audio midi application BEFORE I added the sample high rez file I downloded to the Itunes library?
That would explain why i am still getting the same 16/44 info for all the files!
If you added the file to iTunes only, rather than converted it in iTunes, then it should still be in the original format, it is just that iTunes can only output at 16bit until those setting are changed. I had some stuff that I assumed had been 'downgraded' that once I changed the midi settings, was back to 24bit on output.
Itunes can convert hi res to apple lossless at up to 24bit also, once the midi settings are changed, so that you can embedd artwork etc in the file.
