Hi all. Some of you will know I've just got it, had it lesss than 24hrs now.
A couple of queries if I may.
1 - I had trouble series linking a programme that was on BBC2 in 3 regions. It showed up as a separate recording in each region. Far as I'm aware I did'nt do anything to make that happen. Anyone know a solution?
2 - You can set up favourites but it appears to be useless as there seems to be no way of setting it so that you just see your favourites in the EPG, like with Sky...?
3 - How do you get to a page that shows what recordings you have set up?
I have had a look at the manual but am not getting far.
Cheers.
Cheers.
