How To
How to Set Up a Home Stereo System
Certain kind of music demand and deserve to be listened to only on a full-fledged home stereo system. It is a quick and simple setup, and you can always add more components to improve upon the sound quality. This tutorial will walk you through the steps required to set up a home stereo system.
‘Step 1’
Connect speakers to the receiver
Plug in your speakers to a high-quality stereo receiver using ‘RCA cables’ . Ensure that the polarity of the cables is maintained. The receiver will both process the audio signal and supply power to the speakers.
‘Step 2’
Connect a subwoofer
To enhance your stereo system, connect a subwoofer to the stereo receiver using another RCA cable. A subwoofer will give you a great bass quality.
‘Step 3’
Add a digital to analog converter (DAC)
You can also connect a DAC to the stereo system set up so far. With a DAC attached, all processing will take place here instead of the stereo receiver. It gives a clearer sound, particularly when connected to a computer or an iPod. You will now be able to get high-quality digital sound from your stereo system.
‘Step 4’
Play music on the home stereo system
Connect a music source such as a computer, phone or an MP3 player to the stereo receiver and use the remote or the buttons on your home stereo system to change the settings. You can now play your music on the home stereo system.
‘Enjoy your favorite rock and roll band on your home stereo system.’
