Question How to plug an electro acoustic guitar into a hifi system
cookiemonsteruk
60
32
570
Background i have a marantz mcr6)12 and wharfedale diamond 9.1 speakers
Is it possible to play my washburn festival ea15 through it. What else would i need to buy
I think you only need to buy an adapter - read this interesting thread :-
Reactions: cookiemonsteruk
For the cost of the adapter, its probably worth a try.
I remember in my school days, someone lent me an electric guitar, it worked when plugged into my dad's Boots Stereo Record Player - 2.5Watt. I must have rigged-up my own adapter to connect to the DIN socket on the Boots.
I can't remember the sound quality, but it certainly worked and served it's purpose at the time.
You're best off getting an audio interface and connecting its outputs to the amps RCA. You don't have to spend much. A Behringer UM2 will probably do the job.
I found with my electric guitars through a Helix in to a UM204HD that I was better off with powered monitors,so I sold my Wharfedales and NAD amp.
@clanking intriguing . Guitar has xlr as well as rca. I take it that takes the place of the y adapter with the cable from guitar goes to xlr or inst/rca and then two more rca's go from the back of the module to the rca inputs on the hifi. Fantastic , many thanks 😁
It seems that your particular guitar has a built in preamp - I saw it mentioned that the XLR can be connected to a mixing desk .
Mixing desks accept balanced XLR signals from microphones and line level sources - so you need to confirm the millivolt output from the XLR to be sure that it (probably is) at line level and therefore suitable for connection (via adaption) to the analogue RCA input on your Marantz.
Any guitar / preamp literature you have might give you the output level details.
Not a good idea at all, leaving to one side the risk of damage to tweeters, yes i know that you can turn it down but is doesn't always stay there, the sound of electric pick ups is as much about the 12" speaker as it is about the amplifier.
Best buy a guitar combo amp.
Its an electro acoustic
What are you trying to achieve?
Electro-acoustics exist so you don’t need to mic up the guitar for recording or loud concerts. There’s no benefit to using the pickup for home practice, most especially as even the best acoustic guitar pickups do a poor attempt at capturing the complex harmonics & sound pretty bad.
The guitar will undoubtedly sound nicer played unplugged.
@Revolutions
I realise that now ,having listened to my guitar tutor playing it. Such warm tones from the catalpa (never heard of that tonewood) back and sides . Amazing what you can get even second hand.for less than £200 Guess i am the type to needlessly spend large amounts of money on toys for the boys. Mental note to self "if it ain't broke don't fix it" or i'll be the one who's broke
Reactions: Revolutions
