How to improve my set-up for listening to two channel CD music
Loscozzese
11
I have a Yamaha RX-V3900 which I use about 50% of the time for listening to music (two channel) and 50% for films/TV. I am looking to improve the quality of the two channel music. My music source is CDs through a NAD C545BEE CDP with the Yamaha Amp in pure direct mode and out to my floorstanders B&W 683s.
Reviewing the forums my best option for a jump in music quality appears to be to purchase a HIFI amp and connect the CDP and B&W 683s directly to it. I then connect the Yamaha Amp to the HIFI Amp through the pre-out connections to use when in 5.1 set up.
1. Is this my best option to obtain a jump in music quality?
2. If so, how much should I be looking to spend on a HIFI amp considering my current set-up?
3. Which HIFI amps would you recommend?
T
the record spot
I ditched stereo amps as they were too much of a limiting factor for me. That and the fact that the audio quality of AV amps has stepped up to the plate. With that in mind, I'd suggest you bi-amp your front speakers if you have spare amps in your AV amp left over.
Xanderzdad
146
I'm using the pre-outs of my AV amp into my stereo amp and this allows me to use the same speakers for both stereo duties and the L & R for my 7.1 AV set up.
The great thing is that the AV amp doesn't even need to be switched on when I'm listening to stereo music.
IMHO a decent stereo amp will sound better than a much more expensive AV amp. (Just my opinion - not fact).
Leeps
219
You're perfectly welcome to go this route, but before you part with the cash, it might be worth just trying to play with your current set-up. On my system I find that the musical enjoyment is vastly improved using the Extended Stereo setting which feeds the stereo signal through all available speakers, although I do alter the fader in favour of the front speakers about half way. Crucially, this isn't Dolby ProLogic.
i was genuinely surprised to hear results that were considerably better than Pure Direct, which I had previously assumed would be the best. I don't know what the equivalent setting would be on your Yammy amp.
The reason I find this interesting is that I accept that playing a stereo signal through two speakers powered by an AV receiver may not be quite so 'hi-fi' as a two channel amp through two speakers, but if you have a multi-channel set-up, why not play to its strengths and do something that a stereo amp is not capable of.
The 3D effect I get with my sound playing CD's is just wonderful, and I couldn't achieve this with a stereo amp.
