How to fix speakers on mounts?
Always cut the red wire!
21
Do i have to drill holes into my brand new speakers?
The Apollo stands i have have holes in place but the speakers do not have anything to fit through?
I have a brand new pair of Tannoy Mercury F1 Customs and i really don't want to have to drill holes in them to make them fit to the stands!
Any suggestions??? Thanks in advance.
scene
Blu tak, a blob in each corner of the stand will do the trick perfectly.
scene
Always cut the red wire!:
I've got a little rugrat (crawling baby) so i might need something stronger???
Any others, hard as nails or elastic bands, i'm really stuck!
Yes, any of those will work to stick your liitle one down well away from your speakers...
We bought some extra strong double sided sticky tape from b&q I think, it won't survive a full on attack from a toddler, but it will survive an accidental bump or 2.
