Oh dear....... :O
The ear does process SPL in a logarithmic fashion and works roughly like this.
The smallest change in SPL that can be heard by a 'normal' person is 1dB. Many need a 2dB change to be positive and this is with a test signal.
A clearly percieved increase in level on a music signal is probably closer to 3dB, depending on how the test is done.
A 6dB increase in SPL requires a doubling of amplifier power, a 10dB increase requires 10 times the power, OK so far?
This has implications. For example, a pair of averagely sensitive speakers, say 89dB (1watt, 1meter) produce roughly that level at a normal listening distance in a normal room, this is loud, a more normal 'serious' listening level is around 79dB, requiring 0.1watt, not very much you might think.
So let us play a quality modern recording with a dynamic range of 60dB, remember a CD has a theoretical 96db range. Assuming the average level is 79dB then the average power required from the system is just 0.1watt. Peak level however is 30dB (half of 60dB) higher, ie 10 x 10 x 10 times higher, 100watts in this case.
So you have some new music, or a new bit of kit and invite a few friends round to show off and you turn it up a bit, another 6dB and we are talking 200watts and that is before you build in anf headroom, a professional system will usually have 3 - 6dB, sometimes more.
Choose a less sensitive model, a PMC or a small ATC and a 200watt amplifier is barely adequate and if you are having a party, just forget it.....
Quick and dirty admitedly, but it does give you an idea of what power is required to make a hi-fi system work.
