How do you play this on my TV?
  • Thread starter Thread starter Deleted member 2457
  • Start date Start date
Click download, save as, point it at the usb stick and wait for it to finish downloading. Stick the usb stick into your TV. After that you're on your own, I don't know anything about modern Panasonic TVs.
so I have the USB stick in the laptop I click download and save, just doing it now, then what? Cheers.
I have the file downloaded on my laptop just don't know what to do next? Ta
The_Lhc said:
This is a joke right? I'll play along...
Copy the file to the usb stick and then plug the usb stick into the TV.
Be more specific. 🙂
Right click on the file and select "copy".
Then right click on the USB folder and select " paste".
Then right click on the USB stick and click "safely eject".
Then remove the USB stick from the laptop.
Then insert the USB stick on Panasonic TV's USB port.
Then open the user manual of Panasonic TV to check how to play files from USB.
Be more specific. 🙂
The manual don't state how to play files? Rest done. Cheers.
gel said:
Be more specific. 🙂
*lol*
gel said:
I only have a small manual.
Any help?
gel said:
bigboss said:
You have to change the input or source to USB.
Dont know how to do it?
You must have a source button, or something similar. How do you change from watching blu rays to watching Sky?
