How do you look after your records
I knew I was making a mistake,no I didn't,I was in the process of cleaning my old LPs when it arrived,I just bunged it in the 'wash' with the others,I thought at the time I should have checked it first,but,acting on good information,I decided to clean it before playing in case there was any debrie from the pressing.
In the case of DSOTM I bought a second hand copy off the Bay and it played excellent straight out of the sleeve,only paid £14.02 inc P&P,just goes to show that you 'pays yer money and takes yer chances'.
I wondering now wether to use the Knosti on say 6 discs then empty it,fill it wiith distilled water and run them through again,then leave to dry.
Or (and I know I'm repeating myself) you could do what I do, and put the record with Knosti clamps in place into your drill, tighten properly, and then spin any residue off the record. It works for me.
Yes I agree. I ended up playing my 1973 original copy, and sold the new copy on a few months later.
Sounds like a good idea,so how do you stop the fast spinning record from flicking water all over the place,do you spin it over a bath or something?
Yes I do, but you can always spin outside.
I guess it depends on the tiling you have over the bath (ours goes to the ceiling), and to a greater extent, it depends on what your wife will let you do. 🙂
Do be very very careful though, if the record comes out of the drill, you could quite easily lose a limb.
Imagine trying to explain that away to friends and family... "you were doing what?"
:grin:
It does concentrate the mind somewhat when you see just how fast it's spinning.
pegleg1945 said:
So really my best bet is to share the chores with the misses,I do the washing she does the drying.
:twisted:
I guess there's some kind of equality in that.
One final point. Do place the records on the drying rack for a couple of minutes after spinning to finish off the drying process.
How easy is it to remove it from the drill with one arm?
I just reverse the process of putting the record into the drill. So turn the chuck key a few times, then remove using one of the spindles of the label clamps, then untighten the label clamps from the record, then onto the rack for a final air dry off.
