I would normally always listen to rick @ musicraft, but in this instance, to say that a pre amp of the quality of the DAC XP is the problem in a setup with CM1s, is just plain unfair!
That's interesting. I'd say that my ported IQ7's have much better bass definition than my sealed SA1's. So, presumably, size matters more than design?lindsayt said:The CM1's, bless their little hearts, are far too small and far too ported to get decent bass from, even if you feed them with the best recording in the world, the best source and the best power amps.
It will also be very quietmattc76 said:a single cable into the back of some actives is very appealing.
krlock3 said:I would normally always listen to rick @ musicraft, but in this instance, to say that a pre amp of the quality of the DAC XP is the problem in a setup with CM1s, is just plain unfair!
mattc76 said:Lindsayt - could you recommend any? Preferably second hand. I came very close recently to bidding on some b&w 805s recently (infact I did bid on them but they went only slightly too high), my other shortlisted ones were spendor a6's, some sort of similarly priced dynaudios or the new b&w pm1s but I'd have to buy these new and hopefully try and wangle a good deal on some stands and speaker cable!
Have you heard a DACxp+? I suspect not, having given out that advice. It's almost like saying, "the problem with your Bryston system is your power amplifier".MUSICRAFT said:Hi krlock3
You are more than welcome to differ with me however in my experience i still feel that Cyrus pre amplifiers are not on par with the standard of their source components and power amps.
mattc76 said:Im not necessarily after earth shattering bass but what I do want is real clarity, detail and separation in the bass region
Cpt.Issues said:I found mass loading my stands firmed up the bass a touch but only by a barely tangable amount. If you wanted to seriously add to the presence and depth of bass would you consider adding a sub as an option?
krlock3 said:I was also not that concerned to have big overall bass, just detail and definition.... I have cyrus monoblocks and, even with a lot of power, the bass is not boomy, but it is detailed and defined.
FrankHarveyHiFi said:Beware of taking things too far, as the X Power isn't going to do speakers like the 805's justice.
mattc76 said:Bass depth in itself is not the issue really. I feel that I have enough bass - it just isn't that well defined/detailed like the highs are. In fact I think the balance between the highs/mids/lows is actually spot on (to my ears!). Having said all that, I am ALWAYS a bit disappointed listening to "that low note" on track 1 of the dark knight soundtrack when all I get is basically "port-chuffing" with only the slightest aroma of some sort of musical note. What sort of speakers could do that track justice or would only a sub do?
mattc76 said:...Also my setup does NOT boom. I have the speakers set up either side of a bay window about 3m apart and have half of the foam bungs in each speaker. I can hear the bass and it is in the right proportion to the rest of the music (ie not bass heavy or bass light) BUT I cannot really pick out the bass track like I can the highs (but it is there!).
FrankHarveyHiFi said:I think we need a reminder of what the OP is after - any of the qualities that the OP is asking for, as quoted below, can be had from small/medium sized speakers. In fact, depending on budget, he's more likely to get it from speakers that aren't too big.mattc76 said:Im not necessarily after earth shattering bass but what I do want is real clarity, detail and separation in the bass region
mattc76 said:I have always been given the impression that the X-power was excellent and thus easily able to drive and do the 805s's and I suppose the PM1s justice? Are you saying that these speakers would be overkill for the DAC XP and X-power? Incidently do you think its worth the upgrade from the DAC-XP to the DAC-XP+?
mattc76 said:Wow! A whole load of great responses. I'm on my laptop now so its much easier to reply than on my iphone!
This is exactly what I want - detailed and defined bass. I'm happy with the treble and mids but the detail in the bass is just not there. Also my setup does NOT boom. I have the speakers set up either side of a bay window about 3m apart and have half of the foam bungs in each speaker. I can hear the bass and it is in the right proportion to the rest of the music (ie not bass heavy or bass light) BUT I cannot really pick out the bass track like I can the highs (but it is there!).
FrankHarveyHiFi said:Closed back headphones sound awful - proof that there's pros and cons to everything.... 🙂
About as sweeping as your headphone statement 🙂WinterRacer said:FrankHarveyHiFi said:Closed back headphones sound awful - proof that there's pros and cons to everything.... 🙂
Wow, that's a sweeping statement and sure I didn't mention anything about closed back headphones.
All speakers are trying to convey bass as accurately as possible, or as accurately as their design allows.Perhaps we can agree that active speakers present bass differently to passive speakers?
If so, wouldn't you agree it's worth the OP auditioning some active speakers to see if they make more of a difference than a new (& expensive) pre-amp or power-supply, for example?
