How do i connect a NAS to Denon 3310?
ric71
91
Hi all,
Sorry for being thick but I have no clue.
I want to connect a Nas to my Denon 3310 AVR. Do i plug it into the Netgear router that is hard wired into the 3310?
Will my laptop running windows xp find it? How do I put my photos and i tunes on it ? will the Denon recognise it?
Some one please help me as I really want all my pictures, music etc accessable through the Denon.
I am considering the Iomega 1TB. Any other recommendations.
Many thanks all I really appreciate it and need your help
ric
Yes, you plug it into the router, and yes your computer and receiver should find it no problem assuming the NAS has DLNA/UPnP media server software installed.
Many thanks Andrew,
Do I also need to connect the NAS via Hdmi to the Net/USB input on the 3310?
I will coming to WHF on Wed to take part in the "Big question" so maybe I can get some first hand advice from the guru's over this whole NAS subject?
Thanks once again
ric71:
Many thanks Andrew,
They're completely different connectors, so no. Both should be connected to your router (the amp and the NAS).
the_lhc:ric71:
Many thanks Andrew,
So all media, I know im slow sorry, will be passed via ethernet and if so do I need high quality ethernet cables as plan to listen to music?
Yes all will be passed from the NAS via the router to your 3310 and then the tv/speakers. No you dont need high quality ethernet cable.
ric71:the_lhc:ric71:
Many thanks Andrew,
There isn't really any such thing as "high quality ethernet cables", so don't go to PC World and pay stupid amounts of money for a Belkin cable, find a friendly, independent PC shop and they should be able to run you off however much you need. Ask for Cat 6 cable.
The network cable will not affect the audio quality incidentally, as it doesn't carry audio.
Many thanks and I presume when you say it doesnt carry audio the denon will decode the incoming signal into audio and or picture?
ric71:Many thanks and I presume when you say it doesnt carry audio the denon will decode the incoming signal into audio and or picture?
Zigackly, ethernet carries data, it doesn't become audio (or video) until the receiver processes it.
You are aware the Denon supports these formats only over network?
WMA (WindowsMedia Audio) 32/44.1/48kHz 48 ~ 192kbps .wma
MP3 (MPEG-1 Audio Layer-3) 32/44.1/48kHz 32 ~ 320kbps .mp3
WAV 32/44.1/48kHz - .wav
MPEG-4 AAC 32/44.1/48kHz 16 ~ 320kbps .aac/.m4a/.mp4
FLAC (FreeLossless Audio Codec) 32/44.1/48kHz - .flac
JPEG
Will I be able to store apple lossless and play it through the 3310 this way,( NAS) and poss may want to store full 1080p and master audio movies in the future.
If not what is the best and easiest method
No, the Denon will play neither Apple Lossless nor movies over a network. To do this you'll need to add on a device such as the Apple TV, but AFAIK while this will stream 1080p it will only output it in 720p
Andrew,
Would something like a media streamer with storage connected to 3310 via hdmi be more suitable?
