how can i use sony dav is-10 speakers and sub without av unit
hi
i bought the sony dav is-10 speakers and sub as i was adviced that i could hook them up to a another av reciver however later (after i parted with cash) i was informed that i could infact not!!! i cant afford to write them off so any soltuions(cheap <£150) would be greatly welcomed!
many thanks
Amer
Don't know of one I'm afraid - the speaker system hooks up to the control unit via a dedicated multicore cable, and while you could use the little 'golf ball' speakers with an AV receiver - though they may cause problems, as I think they're only 3ohm impedance or thereabouts - there's no way of hooking up the subwoofer unit to a conventional receiver.
ive noticed the new Sony HT-IS100? which is pretty much the same system as the davis without the dvd player? can that offer a situational? any help will be great!! p.s can you think of an amp/ reciver that i might use?
cheers
Not quite sure what 'can that oiffer a situational?' means, but AFAIK the HT-IS100 is a complete speaker/amp system, so you are again unable to use it with an external receiver.
