HI,
Looking for a little advice from the more knowledgeable here.
I'm about to put a projector and 5.1 setup into my living room. My budget is a little flexible, over £4k for stereo amp/receiver. I have a cheapish projector in mind that will hold me until 4K becomes a more affordable reality.
So the question is this; given that I want a system to cope with music well, and 5.1 channels, and be future proof (to a certain extent) what is the best way of doing that?
I pretty sure I'll buy some B&W CM10s for my two fronts, and a CM mid for the centre channel, not sure about rears at the moment. Soooo, I was thinking about the new Pioneer LX 58 AVR, just announced and available apparently in the next 10 days to run everything. However, reading through all the forums here, it seems the consensus is that a dedicated stereo amp does a noticeably better job with music than a receiver. Is this true of even a pretty good/new receiver like the LX58. I could bi-wire/amp the CM10s for extra control. I've demoed some lovely naim kit, the 172XS/200 NAP through the CM10s, and that was great, although significantly more expensive. So, should I go for:
Naim 172XS/200NAP and a cheap receiver (£600 pioneer perhaps) with pre-outs feeding into the Naim for the front 2 channels?
Or An expensive pioneer AVR and use it for everything? (is there much difference between the LX 58/78/88 other than a few more watts?
Or an Arcam FMJ750?
I hear great things about the Arcam, but the downside is that it doesn't have HDMI 2.0, which I 'think' means that when I come to upgrade the projector to 4k in a couple of years, I'll have to change the Receiver as well, which won't support the higher 4k 60p.
I'm having to chop and change my listening as can't find one dealer who can demo all the above options. so comparisons in different demo rooms is proving hard...
Please help.
Or an Arcam FMJ750?
Please help.
