- Aug 10, 2019
- 2,556
- 5
- 0
Hi there ladies and gentlemen
I am a novice in need of a bit (possibly a lot) of advice on my home cinema project. I will list my questions individually, but also If I could have some overall comments about my proposed system, it would be most appreciated.
Projector - InFocus IN76, InFocus IN78, Planar PD7010. Which projector should I go for and why? Is there much difference between the IN76 and the IN78?
AV receiver - I am currently torn between the Onkyo TX-SR605 and the Yamaha DSP-AX861SE. I am of the understanding that the Onkyo supports more recent HD audio codecs, but is the Yamaha a better receiver? Which would you recommend?
Style speaker packages - I am really torn here although I am leaning towards the Quad L-ite system. The others that I am cosidering are the Kef KHT3005SE and the B&W MT-20. Any recommendations here?
As you can see, I need a lot of advice. Apart from comments on the individual components, what are your thoughts on the overall package. Are there any other compnents that you would recommend for similar money.
Many thanks.
Chris
Many thanks.
Chris
