Just to make sure, is your question to find out if your setup will technicaly support hi res files? Or if it will be "good" enough so you will hear the difference ?
If it's the first I'm not sure but technical spec are usualy easy to find in the net. If it's the second, the amp and speaker will make a good impact on your sound quality. So it's hard to say with the info provided.
All I can tell you is that hi res file played on my laptop pluged (analog) on my 250$ Sony SRS Z-1000 desktop speaker don't make any difference at all. :-(
But the same file on my UnitiQute with lo fi JBL 300$ speaker is making a huge diffrence, I can hear the difference big time.
Hope that will help.
