High or adjustable speaker stands?
Hey now that I have decided to buy the RX6 and pioneer sc-lx72 I need to move my rx1 to the rear.
I dont really want to wall mount as the speakers are quite heavy and the ones that will mount dont really angle down that much.
I have an L-shape sofa, so need to get the speaker above the side which is about 3 1/2 foot tall.
Is there such a thing
thanks
Atacama Nexus comes in 100cm, which would be just about right I'd say, as would the Apollo AZ10. Apollo also do the SR, which are height adjustable, but look a bit flimsy. YMMV.
EDIT - course, some say that the rears should be a couple of feet above your head...
Thanks for that John, the atacama look about right, but those atibites are so expensive ,can you fill with clean dry sand?
