HifimeDIY dac
drummerman
540
Not much happening here with regards to new products so here is a little blurb about an old one;
I use one of these with a CCA. Fantastic value at around £40.
It uses one of ESS's Sabre chips, the 9018k2m. It has been used for a long time in numerous products, usually more budget orientated and was, I believe the succesdor to the 9023. For high end they have their PRO chip (now the 9038). Incidentally there have been quite a few measurements done suggesting that iteration can suffer from higher than usual jitter.
The 9018 measures superbly, near the top of what is possible with off-the shelf chips, even today. Sound is peppy and lively. Compared to the CCA's decent built in DAC it does add a little clarity and life.
If you have a slightly soft sounding system or simply want to improve a little and cheaply on the CCA, it's great. That it is also small and can simply hang out back next to the Chromecast is an added bonus.
Hifime do different models depending on connection required.
A perfect stocking filler or just as a cheap present to yourself. She wont know, either from the bank balance or by looking at your hifi.
Some of the best money I've spent on HiFi along with the CCA.
Happy Days.
Definitely a good value solution. I've only used CCA for a day but didn't work for me due to network issues. Should I love the sound I'm sure I would've kept it. Wonder what it be like if I used this dac back then.
Insider, I would be interested to read a little more in-depth impressions on the Roest and 160 if possible.
Ok, I'll fire up a PC, put the kettle on and will do a write up. Sorry, it's been a little difficult doing it from the mobile and I've not had a chance to sit down in front of a PC for a day or two. Should have it ready by noon.
insider9 said:
Just lost an hour worth of typing... *dash1*
Stupid, stupid website design!
Yes, happened to me previously though I can't remember having ever typed for an hour ;-)
Appreciated but doesn't have to be done today.
Well, you know my posts... they're usually long. And I can type with reasonable pace also.
I'll type it up in a separate document and copy and paste once finished.
I have one HIFIme sabre 9018 not shure if it's this one that i think is the upgraded version https://hifimediy.com/DACs/ready-made-dacs/Sabre-9018-DAC
The dac has a bit sharp top, theres something wrong with the top and the midbass is a bit fullbodied, so after 3 cables i desided on a studio interface, you know,neutral revealing sound, the one that was on sale because a local store opened a new place, i couldn't get, so i got for the same price a Focusrite iTrack solo and it sounds good with no sharp top and the midbass isn't fullbodied, a neutral sound
drummerman said:
The dac has a bit sharp top, theres something wrong with the top and the midbass is a bit fullbodied, so after 3 cables i desided on a studio interface, you know,neutral revealing sound, the one that was on sale because a local store opened a new place, i couldn't get so i got for the same price a Focusrite iTrack solo and it sounds good with no sharp top and the midbass isn't fullbodied, a neutral sound
Looks good compared to other semi pro interfaces. Dare I say that the full midbass may have something to do with your NAD amplifier.
As to the top end ... you are right, ESS DAC's, any of them, have been reviewed as quite revealing up there, perhaps even a little forthright (don't ask me how an essentially flat measuring DAC can do that) so system matching is, as always, a good idea.
Wolfsons reputedly sound a little more flat and may benefit some systems.
I don't have the fullbodied midbass with the new focusrite interface, still for there size the bass is good, better than the boston a23 i once had (about the same size).
Looks good compared to other semi pro interfaces. Dare I say that the full midbass may have something to do with your NAD amplifier?
As to the top end ... you are right, ESS DAC's, any of them, have been reviewed as quite revealing up there. More so than some others (don't ask me how an essentially flat measuring DAC can do that) so system matching is, as always, a good idea. - The same trait probably has also something to do with the perceived 'speed' of the DAC.
Just when I said the 9018 ESS as used in the HifimeDIY is associated with budget products, Convert Technologies' Tempus (HN&RR Jan 2018) uses the chip. £10,000.
I think the Mark Levinson 585 als uses the 9018. £12500.
