hi-level sub inputs
When using the hi-level input on my sub (mj acoustics pro50 mk2) as well as the low level do should the crossover be set to the same as the speakers or low level ie.80-90?
mark hooper:When using the hi-level input on my sub (mj acoustics pro50 mk2) as well as the low level do should the crossover be set to the same as the speakers or low level ie.80-90?
Set the high level to roll off just above your speakers (mine speakers are 32hz sub set to 60hz) and manually adjust the high level volume so all integrates well
For low level set the low level sub volume to 12 o'clock and let your hc amp calculate the cross over settings
Apologies for dropping in on this thread, but on the same subject - my high level connector (same sub as Mark's) has three wires - red, white and black (I think) at the amplifier end. What do I connect these to?!
muchy:
just check your instructions but normslly two positive inputs and one negative so red to red black to black and white/yellow to the other positive terminal red
Hi muchy if u go to the mj acoustics website there is a page on there that tells u all the different ways u could connect to your amp using a speakon connector.
