Hi-Fi Rack / specific dimensions required (500mm or so wide)
Juzzie Wuzzie
527
318
19,270
I'm struggling to find a hi-fi rack to meet my needs - specifically - but dimension. Can anyone recommend a rack that is (whd) 500mm (or less) x 800mm (or less) x 500mm (or less)? The CRITICAL measurement is that the rack is not wider than 500mm, which is proving difficult to find.
Appreciate the help.
I would 2nd Ben's recommendation - as long as the inside dimension is wide enough for a rack that's 500mm - you loose some due to the width of the legs.
Fantastic suggestions - would presently need to go custom size - so now have permission to remain with the ('that thing is ugly') rack until we shift house - at which point I am all over these racks, in standard size.
Thank you to both for the help.
