- Aug 10, 2019
- 2,556
- 5
- 0
Hi everyone,
Im new to the site and quite new to amp and speaker set ups, so some patience may be required
Heres my story, i'll try and keep it short:
I have a large garage where I have regular parties at high volumes and long durations. I had a Pioneer Midi system for this which would cope with being at high volume at long periods of time, it did so for around three years and is still working.
I decided to 'upgrade' to an amplifier and speaker system for better quality sound so decided I bought a Yamaha AS500 and two Mordant Short Aviano 2 speakers. I am supplying the music through a laptop via a headphone jack cable with pre out ends to the amp.
I set it all up correctly to instructions, and organised a party. After about 2-3 hours of running the set up (around half way-three quarters...but never anywhere near MAX) the amp cut out. I assumed it had overheated. So turned back on at lower volume.
A few days after the party, I turned the amp back on and the sound quality had all but disappeared and everytime I turned it up to about half way it would cut out again.
Assuming that there was a problem with the amp, I took it back to the supplier and they sent it to Yamaha to be repaired. A few weeks later it returned, I tried it out and the same happened again!
To completely rule out the amp, I returned it to the supplier and exchanged it for a Marrantz 6004, took it home and tried it...yes, youve guessed it, speakers still sounded rubbish and amp would still cut out.
I checked and double checked all connections, then tried out some other old speakers which worked fine and the Amp did not cut out! (before you say it, yes I know I should have tried this originally!)
With the speakers in the firing line, but not visibly damaged externally, I dismantled the speakers from their enclosure to find melted plastic over the orange coils (capacitors?)so I guess Ive worked them too hard and fried them?
So, in a nutshell, im looking for a pair of speakers to pair up with the Marrantz, that will be able to cope with high volume for long periods of time....
Or...
Am I asking too much for a £300 amp and £250 speakers to be able to cope with these parties and should i be looking at a completely different set up?
I know there maybe some info that I havent included above so I will answer any questions you may have to try and find out what I need to do. Thanks in advance.
Matt
Or...
Matt
