alextsak
12
My Sanyo turntable has a lot of hum (especially after a certain volume level), do you have any solution for that? (Grounding is ok)
PS. sorry for my bad English :/
alextsak
12
I mean that it is properly connected. The hum is louder when i remove the grounding wire and the turntable is attached to an old JVC Amplifier.
alextsak
12
What is the model of the Sanyo turntable?
Is that old amplifier actually ground at the mains socket, I mean does the power cable have two wires or three?
It has 2 wires but there is a grounding socket on its preamp.
The model is SANYO plus serier quartz pll direct turntable PLUS Q25.
alextsak
12
If you can, maybe post us a picture of your setup.
Was the cartridge pre-fitted or did you do it?
I cant send a photo, I have swapped the cartridge but the hum was there with the old one too(which was pre-fitted)
