I'm currently rebuilding my front room. It has been completely gutted and is in the process of being rebuilt. I have already started the plasterboarding and have put in place trunking for speakers. However, I thought I'd have a look online recently to double check my speaker placement and, it seems, things have moved on. Now I'm uncertain about the plans I had in place and would welcome any words of advice before I am committed (the plasterer is coming in December!!!) and miss this ideal opportunity.
I was going to use Monitor Audio Silver 6 fronts and centres (I considered in-walls for a while) )and then use 4 x CT256-FX speakers for the surround and rears to create a 7.1 setup. However, I am not convinced this will provide me the best solution. It seems that Atmos and other 3d sound solutions are all the rage and my initial proposed apporach will not support this. So, here's latest proposal.
The square boxes are the fronts, centre and rears. I am intending these to be the Monitor Audio Silver 6AV12. The round boxes will be in-ceiling Monitor Audio CP-265 speakers. My configuration/placement does not seem to meet the Atmos spec but does approximately reflect the 5.1.4 setup detailed in the Yamaha 3050 Receiver manual. With a bit of effort, I could move the front high speakers further towards the sofa which would appear to more closely (but not precisely) match the Atmos spec for 5.1.4. Should I do this or will they be OK where they are? Is there anything else I should be considering?
I guess I looking for some confirmation/reassurance that my approach is good (or at least) not bad. I don't want to splash the cash but still end up with a sub-optimal solution due to poor speaker placement. Any help, advice or recommendations would be gratefully received.
