Help to choose between Stanton and project
Thebot
Hi, am new to the vinyl world. In the local sale I saw Stanton t92 and project primary e been listed. Though am not a DJ and not buying turntable for that but the Stanton build looks solid. The project primary E costs high when compared to Stanton. But I have seen lot of reviews about the ausio quality. Please help to choose between Project or Stanton from the beginner perspective.
Gray
It's possible that the Stanton looks more solid than it actually is.
Not that the Project is anything special in that regard, so don't let that be the decider.
Stanton has a built-in phono preamp (which means you could use it with an amplifier without a phono input).
It's also got USB if you want to digitise vinyl.
Depends on your requirements.
The Project would give you a hi-fi deck, with nothing you don't need (such as a variable speed control) more importantly it's likely to sound better, for that reason it's probably your best choice (although in an ideal world you could confirm that by listening).
Reactions: Thebot
