Red Dragon:maxflinn:Red Dragon:
maxflinn:no alcohol for me tonight but i'm loving spotify, it's fantastic
As a fellow Irish resident Max, I am keen to try out Spotify but find it unavailable...how are you getting around this availability issue ??!
you need to use a proxy server to hide your ip address, then once you have opened a spotify account (start with spotify open) you log in, and download the app...
you will need a little help from someone in a spotify "country" to help you upgrade to premium though..
edit......
go here then paste this
https://www.spotify.com/en/get-started/ into the box, then press go. you will be taken to spotify where you select the "open" option, then open the account and download
Will give that a go thanks a million Max (again)...does this still mean I have to use a uk based email address then or what ?
no, but use a uk postcode if asked, w127rj is fine. once you've opened the account, close the tab, then go to spotifys website as normal, and log in, then scroll down to the bottom of the page where you can download it, by clicking on mac or windows..
edit....when you are first taken to spotify, click on get spotify, then "open"...
good luck
edit......
good luck
