Help setting up my Denon AVR-1610 for 2-channel stereo
Bromiley
48
8
10,545
I'd like to buy the new B&W 686 S2 speakers and have a 2-channel set up. Unfortunately, my budget at the moment doesn't stretch to a new stereo amp with optical connections. Therefore, I'd like to use my old Denon AVR 1610 until I can get a new amp.
I have a bluray player, an Apple TV and would also like to have sound from the speakers whilst watching TV.
I am familiar with setting this amp up for 5.1, but am not sure about setting it up for 2-channel.
Can anyone give me some advice? For example, do I still use the Audyssey set up? What settings do I need to use on the Denon AVR? The manual for this AVR isn't easy to understand.
Thanks in advance.
mmg
37
Normally it should be enough to just run the Audyssey set-up: it should automatically detect what speakers are in use, measure them and set all the settings in the amp accordingly.
You can verify if Audyssey did a good job by going to "speaker setup", then "speaker settings". All the channels should be set to "none", except for the front speakers.
