Hi Guys
I am sure this is trivial but if you dont know something you need to ask.
I am looking to put a Yamaha Z7 into my system - I will be looking to wire a Blu Ray and Freeview box via HDMI to the Yamaha then to my Pioneer LX5090.
My Question is to get the most from the TV/ Source I have the drive option different for each input.
If I wire direct from the amp then I will only be using 1 input on the plasma and can only have one drive option selected.
Is it best to pick one drive option and be done with it or wire the freeview to the tv separate - obviously I want the HD sound from the Blu Ray.
The freeview box already upscales to 1080p and does a bloody good job - hence why i would wire this one direct.
Thanks for your help
