Hello all,
I would be grateful for some advice. My new Roksan Kandy K2 has now arrived, and along with MA GS10s sounds lovely. However, the spade connector on the "earth" on the Phono stage on My Project Debut II doesn't fit the terminal on the amp. I am a bit ignorant on the mechanics of Phono stages. I don't know if the Project is MM or MC, and if I'm perfectly honest, other than what they stand for, I don't know the difference. I've worked around the problem by using my Arcam A65+ as a Phono amp and taking it's Pre Outs into a line input on the Roksan.
I'd be grateful if anyone could tell me how to connect the turntable directly to the Roksan, and if I need to buy a separate Phono stage, or alternatively, if using the Arcam is the best bet.
Many thanks in anticipation of your help in avoiding an expensive mistake.
Shuggie
Shuggie
