HELP!!! My current telly is on the Blink. I have decided to get either the Sony KDL-46T3500 or the Philips 47PFL9632D, which is best???????
any reason for the LCD only choice?? Panasonic have a new plasma in 46... also plasma beats LCD by far in terms of black levels and motion blur so take a look at some plasmas ;)
if not the panasonic (TH46PZ85B) other sizes vary from 42 and 50 ish =/
Hi I have just bought the Panasonic TH46pz85 after much consideration inclding the top of the range X series Sony and the fabled Pioneer range,
The panasonic won hands down on price picture, quality on SD/DVD and blue ray.
Cost About £1500.00 at the moment and in May comes with a 5 year warrenty for participating dealers as they say!
A bit stereotypical but my wife is very impressed.
[quote user="matthew s"]any reason for the LCD only choice?? Panasonic have a new plasma in 46... also plasma beats LCD by far in terms of black levels and motion blur so take a look at some plasmas ;)
[/quote]
Or the TH46PZ80, just about to hit the shops.
I want an LCD as I am concerned about screen image burn as we watch a lot of SKY. Have you noticed this problem with Plasma?
Well, screen burn isn't really an issue for plasmas nowadays - do a search in the forum for "screen burn" and you'll see many posts about how this problem has been solved from modern sets.
[quote user="Bad Chow"]
[/quote]
Your fears are unfounded Bad Chow, I wouldn't rule out a plasma on the premis 'screen image burn' is an issue, it's not.
