help Musical Fidelity
i have a Musical Fidelity Elektra E20 the problem i got is that the mute is on and i dont have the remote control help
you could try asking MF directly or failing that if you know of a dealer who might loan you a remote. I dont know if the newer gear is compatable with your elektra but it's worth a try.
thanks for a quick reply How did you Mute it in the first place?? my sony rc turns it on but wont turn of i have got Marantz RC3200 but carnt find code for Musical Fidelity i will try switching it off at the mains hope this works will let you know if it works
yes it work switching it off at the mains thanks still need the code for the rc tho great help thanks gregory and Messiah
