Help for a turntable newbie
Hello,
I will preface this by saying I know absolutely nothing about turntables! However, I want to buy one for my boyfriend's 30th so I was hoping for some advice.
Firstly, would you recommend buying a turntable with an inbuilt phono stage or a separate one? The CD player he has is an ONKYO CD515 - would a turntable connect to this ok with a phono stage? Would I need to buy anything else?
Secondly, is there a big difference between the Pro-Ject Essential and Pro-Ject Debut?
Thanks for any advice!!!
S
Captain Duff
What a lucky b/f you have ;)
Ok, first a 'straight out of the box' complete turntable with arm/cartridge/leads sounds to be just what you need. Both the Pro-jects you mention are great in that respect, the differences between them mainly come down to the Debut having a slightly better arm and cartridge so it should sound a bit better - however you need to think how much it will be used to really work out if the extra money involved would be worth it (the Essential is a great product at a very good price). Also, another one to consider in that price range would be the Rega RP1 which is another complete product.
As to whether you need a phono stage (which is a mini amp booster as the signal strength from a turntable is lower than that from a CD) depends on what amp he has (as the turntable would be plugged into that, not the CD) as some amps have built in phono stages, some don't - however I'm wondering if what he actually has is the Onkyo CR 515 which is a one box combined amp, radio and CD player? If it is, then no it doesn't have a built in phono stage, so you would either need to get a seperate one, or a turntable with one built in. Both the Pro-ject models you mention come in versions with a built in phono stage (and also USB which allows you to transfer recirds to digital formats), or Pro-ject also sell a seperate phono stage box for around £60, although many other phono stages are available at various prices and you don't need to have the same brand as the turntable itself.
Thank you so much for your help! I had been trying to piece together what I needed from various forums and reviews etc but it's great to have it in plain English!
You're correct that the Onkyo he has is amp/CD/radio all in one, so I will need to get a phono stage. What would you say are the advantages and disadvantages of separate or inbuilt phono?
Thanks,
S
The_Lhc
1,176
An inbuilt one you know has been designed to work well with that deck and won't require a separate power supply but a separate phono stage will give you the option later of upgrading if you feel like you want to improve the sound.
Ok, that's great, thanks for the advice. I think I will go for the Project Debut 3 Phono SB then. Sounds like a good option for a starter, ready to go turntable!
Thanks again for the help!
S
