Help.. Denon AVR-1909 Panel Lock is ON.
radovantz
64
Good day everyone. I need some help. My AVR-1909 has automatically turned on it's Panel Lock.
This problem occur when I tried to reset microprocessor. What should I do to turn off the Panel Lock?
It is not mentioned in the Manual. All buttons and knobs are disabled when Panel Lock is on.
Any advice? Thanks
Thank you for the link, Simonlewis
Problem solved, my AVR is reset to factory mode by following this steps:
1) turn off the main power button (not the big LED stanby button)
2) press and hold "input mode" and "speakers" button simultaneously
3) press and hold the main power button for seconds, until display flashes.
4) release all those buttons. The AVR is already reset to factory mode.
