Hello and need help about my vintage Hifi speakers
burakmu
Hello
Im from Turkey Istanbul. Firstly Im sorry about my bad english. I found this Hifi Grundig speakers from flea market last weekend and I dont found any information about this speakers. Its 62 cm tall and 19 kg weights. woofer diameter is 28 cm. I cant open front grill and I see one big woofer circle and four little circles outside the front grill. I need open front grill and need information about this speakers model number. Front grill and back side is closed and not attached with screws.
Pictures of my speakers
http://i.hizliresim.com/57Xbpd.jpg
http://i.hizliresim.com/4rQXYq.jpg
http://i.hizliresim.com/0ng9bL.jpg
http://i.hizliresim.com/A7NWZq.jpg
Hello and welcome. I cannot give you a model number, but I am pretty confident from that brand's history and the captive cables they are nothing to do with hifi! They are probably from a music centre (a combined record player, radio, amplifier - all in one unit) from the 1970s.
If they work at all they will probably sound dreadful, and are quite likely broken in some way. You can wire them up to an amplifier and try them, gently at first, to see if they make a reasonable sound. But I'm afraid they may not be what you were hoping.
Sorry to sound negative, but I'm trying to be realistic. Good luck!
burakmu
Hi
Firstly thanks for your answer. Yes maybe its a music center speakers , cables is very bad. I connect them to my Dual CV1450 amplifier and its working. Sound is very good for its age. I need remove the front grill for see the woofer and mid speakers but I cant open. Have you got a idea about remove the grill ?
Thanks again.
NJB
75
My Dad had some similar style speakers. The grills were not designed to be removed. If your speakers are the same, then you would have to completely disassemble the cabinets as the grill mesh will probably be held in with staples inside. Be warned, there is a strong risk that the speakers will not survive all this activity.
burakmu
Yes I like this speakers sound. I need open front grill for see the woofer and mids status and number of units. I dont see inside of the grill but feel four little circles and one big circle of woofer. Sound is really good for its ages. :)
