Headphones
Nadeac
69
Bought a pair of Audio Technica AD700 headphones 6 months ago and already they are starting to fail.the left speaker goes off now and then ,looks like they may be going back under warranty
If u tap the speaker it comes back on then seems to ok for days ,what im gettin does anybody know whats actually happening when a speaker goes off and tapping it brings it back to life .Its as if something is sticking
Thanks Mark
sounds like a loose wiring connection or solder joint. when you tap the headphone you will temporarily reconnect the loose connection... take them back for sure - i would be very surprised if the dealer wont accept them return!
