Does anyone have experience of the higher end Grados like the GS1000e and how they compare to the Senny HD800?
I'm wondering if I made a mistake going for the 300 ohm HD800 rather than choosing something easy to drive like 32 ohm Grado.
I've been using Macs / Audirvana Plus into a TEAC UD-501 and then out to a Pathos Aurium. Unfortunately I'm getting distortion on highs on the HD800 when connected to the Aurium. This distortion disappears if I use the headphone output on the UD-501 but this unfortunately means I have to sacrifice the warmth of the Aurium amp.
I've also tried a PC and J River MC and the distortion appears again. I know the HD800 are not defective. I suspect that the software / USB decoding is the issue but I'm none the wiser as to why it is all OK until I use the Aurium for the amplification. The Aurium has no issues if I use SPDIF / coax into the DAC. So it is USB / software at fault.
Has anyone else had an issue like this?
I have a pair of Grado 325is and they don't distort at all. But they are a long way short of the HD800 (sound, comfort and listening fatigue). Hence why I'm interested in forum user experience of higher end Grados.
