thank you for the replyIf you mean using one of the input sockets on the Myryad, you could do it, but you’ve then got two volume controls in the signal path, so you have to decide which one you’re using - if you want to mainly use the volume control on the Myryad, set the Rotel volume to the 6 o’clock position - it if you want to use the Rotel volume, set the Myryad to the 6 o’clock position (if it’s a normal volume pot) and then use the Rotel for adjustment.
