HDMI cable
aliEnRIK
92
Hi all
I use my computer as my main source and I am posting to ask for advice regarding hdmi cables. I want to output 4:4:4 @ 60Hz and 10 or even 12 bit. The first two cheap cables off ebay completely failed and wouldnt even show 8bit @ 60hz. The 2nd set of 2m cables were from amazon and they faired far better in that they at least showed 10bit @60Hz but only at 4:2:0 but have drop outs on anything over that. What cables (The cheaper the better, they should just 'work') can you recommend that are guaranteed to do the job?
Deleted member 2457
I think you need something like this:
https://www.amazon.co.uk/dp/B076GYTPGD/ref=psdc_1338421031_t1_B015WV0Z92
I think it needs to be a premium cable.
abacus
If you’re going for that high level you need to make sure they support 18GBs at the length you require, I would also suggest good shielding and gold plated connectors (To reduce corrosion) and should not cost more than £10 for a 1m length. (Avoid anything made by Hi-fi cable manufactures as they just rip you off with gobbledegook)
Bill
