Hi all, I’m new to this forum, so be nice!
I have a simple question which I hope can get a simple answer.
I am running a Yamaha RXV371 receiver which I know isn’t the most expensive one out there, but I’m really happy with it. Connected to it I have my Sky+ HD box, my Xbox and Apple TV.
The Yamaha takes an HDMI feed from each source, then feeds the chosen signal via one HDMI cable to the TV (which is an LG 50inch Plasma 1080p).
I have an assortment of HDMI cables. One very expensive one, two middle of the road and one standard quality. My question is what is my best use of my expensive HDMI cable? Do I use it from my Sky box to my receiver, then the middle of the road from receiver to TV, or do I use the expensive one from receiver to TV, as all the sources run into that? I use the standard one from my Apple TV as its the pre 1080p version so not HD quality.
I know in an ideal world that I would have the best quality cables I can afford, but I just don’t have the budget to do that, so I need to work with what I have.
Any advice?
MIL5419
Any advice?
MIL5419
