HDMI cable help - which needed?
I have the following items on order:
Panasonic PX70 plama TV
Onkyo 605 amp
Toshiba EP35 HD-DVD player
Am I right in thinking that all I need to connect these together are two HDMI cables (1 from DVD to amp, 1 from amp to TV)? Does the aerial lead plug into the amp if I want standard TV broadcast sound through the AV amp, or how does that sounds signal get to the Onkyo?
Sorry for the basic question - my first stab at setting this sort of kit up.
Thanks in advance for any help.
Rob
Andy TW
6
The ariel lead should be plugged into the TV. Then you need a stereo phono lead from the TV audio outputs to the amp to allow you to listen to standard TV broadcasts via the amp.
Great thanks. Plenty of stereo cables lying around so it looks like I've only the 2 HDMIs to buy.
Cheers,
Rob
