- Aug 10, 2019
- 2,556
- 4
- 0
I have my Sony DVD-Recorder (Model HXD750B) hooked up to my Sony Home Cinema (HT-SF1300) via a direct HDMI cable. My Home Cinema output is connected to my Sony KDL 32W4000 HD LCD television input again using HDMI. No problem so far.
My aerial cable comes from the wall socket to the DVD-Recorder and then on to the television, as per he manual.
I understand the HDMI cable carries both picture and sound, so why do I need to make connections for digital audio as well? Precisely which units should be linked with digital audio connections, and should I use digital coaxial cable for this purpose?
Should I connect my television for audio to the Home Cinema unit, and if so, from which output to which input on the amp?
Any sympathetic assistance you can give would certainly help sort out my confusion.
