HD Audio through 5 speakers?
is HD audio (either DTS or DD) only supported if you have a full 7 speaker setup? I appreciate you'll lose some of the direction and spatiality with only 5 instead of 7 speakers but one of the added benefits of HD audio seems to be the improved quality of the sound itself (due to the larger bitrate/lossless encoding, etc). Would you still benefit from this with only 5 speakers?
Slight thread hijack:
I am looking to put together a surround speaker package which omits the subwoofer. Although I do watch movies in surround, I am more interested in music. The reason I am a bit anti-sub is that I have a very small square living room and where ever I place the sub I can hear it as a separate entity. Also, I am not really into big bass.
The QAcoustic 1010 small bookshelf speakers get good reviews as stereo speakers. If I were to get two pairs plus the matching centre, do you think that would be adequate as a budget music surround system?
*edit*
As an alternative, how about using the 1030 floorstanders as the fronts and the 1010s as rears?
Halloway:Slight thread hijack:
*edit*
My old Sony amp has the option to omit the sub, which sends all the base signals (sorry, non techie talk
) to my Mordaunt Short front free-standers.
I get all the base "Rumble" I need from action movies etc, and have used it this way for 9 years.
I would imagine all receiver amps have this option?
How small is small? My living room is not much more the 12ft x 12ft but my 1000 wattÿ(although admittedly pretty tiny)ÿVelodyne SPL-800i works great in there.
