CnoEvil said:
BenLaw said:
CnoEvil said:
I would recommend talking to Darren of Clearer Audio, as he's very helpful and I rate their products (which have a trial period): http://www.cleareraudio.com/ The best measurements that may indicate how better mains cables work, is provided by research from Shunyata: http://www.shunyata.com/Content/DTCD.html http://www.shunyata.com/Content/DTCD-meas.html http://www.shunyata.com/Content/DTCD-indepth.html http://www.shunyata.com/Content/DTCD-whitepaper.html http://www.theaudiobeat.com/visits/shunyata_visit_interview.htm
Isn't the purported relevance of these measurements utterly undermined by this comment? -
DTCD tests are an extreme test of the limits of power cord performance and do not represent normal operation into a power supply
Good point, but I suspect that they wouldn't have spent thousands of hours and hundreds of thousands of Dollars, developing a machine that was fundamentally flawed from the off.
Well, it's not necessarily fundamentally flawed, as it may well have achieved exactly what they want. As they have control over the amount of power it seems to me they could probably simulate realistic conditions. Which probably means they have. Although they haven't published those results.
In the FAQs, somebody asked something very similar (I think) - "Why is the amperage in the graph so high?"
The answer - "You may be thinking your CDP only pulls 1 Amp and your amplifier 12 Amps. So how can a test be valid that shows the cord drawing hundreds of Amps of current?
Read the DTCD white paper. Power supplies only pull current for 5% to 10% (or less) of the AC duty cycle. During the conduction period, the instantaneous current could be hundreds of Amps, but the long term average is only 1 to 20 Amps, depending on the device. Nb. If a power supply is drawing 20A (as measured by a current meter), then the peak current would be 100A to 200A instantaneous current"
So it would appear that this device is designed to" test a single current pulse".....so it needs to "simulate the AC electrical power grid, with its characteristics as a constant voltage source" as well as "mimic the action of a typical power supply when the rectifier turns on and off to fill the power supplies storage capacitors."
I'm not sure if this answers your query satisfactorily, but it's the best I can do.
Fair enough. I quoted what they put, it wasn't my assessment. It seems to me they say 'up front' it isn't really valid, perhaps to avoid the sort of Russ Andrews liability, and a bit deeper try to row back from that. Seems inconsistent, at the least.
Apparently "comparative subjective listening tests have been conducted spanning several years, under controlled conditions using blind and double blind tests, that repeatedly confirm the connection between system performance and DTCD. The results will be published along with more detailed information, in a series of supporting FAQ documents."
These would be very interesting to see, please post as and when you become aware that these have been published
Also on this section of the site:
These results represent a solid, empirical foundation for continued research into the relationship between AC delivery and pro-recording or A/V system performance.
This seems like a reasonable statement to me.
OTOH I can see no support for the conclusions they claim to have reached, in the first FAQ, which also seem to be inconsistent with the part I've just quoted:
1. There are audible and visual differences between power cords (and other AC power products).
2. Some of these differences can be directly attributable to Dynamic Transient Current Delivery.
The main thought that occurs to me with this is that no objective testing appears to have taken place prior to the manufacture and distribution of their products. And as they claim this is the first machine of this type developed, the implication is no other manufacturer has ever measured their products. This does not seem an impressive approach to me.
I should say, I am as yet an agnostic with mains products, and in particular would like to get the chance to try a good mains regenerator, although I don't expect to get the chance for a long time.
