Has anyone tried SEWELL banana plugs?
KrisC123
6
im looking for some decent cheap banana plugs (i prefer them just for ease of use)
I found these http://www.amazon.co.uk/gp/product/B005E1CGZC/ref=olp_product_details?ie=UTF8&me=&seller= pretty cheap for 6 pairs, but are they any good?
ive tried several pairs of banana plugs, 2 different types of cambridge audio banana plugs that seem quite loose in my denon DM39 and even more loose in my speakers. ive tried cheaper ones which were more snug but were fiddly and cheap and broke pretty easily.
Any advice is welcome :) thanks
ayjaycee
59
I use some that look identical but are marked Nakamichi - had them a while and can't remember where they came from although it was probably an Ebay shop. As Kris says, they are a nice tight fit and seem to provide a good connection. The only issue that I have had with them is that the 'barrel' cover seemed to come loose very easily but a tiny drop of superglue sorted that out (but they would still be easy to unscrew if needed).
Hope that helps.
ASK THE COMMUNITY
