Has anyone bought speaker cable from futureshop.co.uk
D3CYPH3R
31
Hi, I'm looking to buy 4x 5m lengths of Chord Carnival Silverscreen and these guys will terminate with chord plugs and offer a 10year guarantee on the work, but seem considerable cheaper than anyone else, anyone used them before?
thanks in advance.
Yes, used them many times.
First class service in every respect. Good advice by phone if you need it..
Delivery usually arrives next day if you order early.
D3CYPH3R:
thanks in advance.
Are you going to bi-wire?
If yes, there is a bi-wire verson of the cable you want to buy. Just FYI.
Bought from Futureshop many times... No issues.
And they were helpful to help on my purchase when necessary.
I plan on bi-amping, but would like the option not to if i plan to do things differently in the future, felt that i'd have more flexibility having separate cables.
Hi, I too have bought cables from futureshop.co.uk and had good service.
.....cheap does not always mean bad...thankfully.........
Cheers.........d'(mmmmm)!.
