chebby said:
kevinJ said:
It depends on what speakers you want to use it with. Take a look at the specs first: the 505 draws 210watts max, the 507 max 250watts. Both are analogue amps and those have an efficiency of only 50%. So the 505 would only have 2 x 50 watts to feed the speakers...
Luxman's own specs claim 100w + 100w continuous power into 8 ohms for the L-505U.
As for your means of culculating power output, then I can see no correlation between power consumed and peak or maximum power output.
For example, the AVI 9.1Ts are quoted as 325 watts per channel (250 watts for bass/mid + 75 watts for tweeter) X 2 = 650 watts max in total. They use 'analogue' or class a/b amps so, by your equation, they should draw 1300 watts from the mains! With 50 percent efficiency - by your argument - they should be dissipating up to 650 watts as heat during dynamic peaks! AVI claim 40 watts total 'draw' from the mains at normal domestic listening levels (in their FAQ) so - given that this same disparity exists on the specification pages for a lot of major companies amplifier products - something else must be going on. (Or they are all guilty of lying, or they are all breaking the fundamental laws of physics!)
Chebby, you might want to google how an amp works and the laws of physics that apply to it because I don't feel like posting my electronics handbooks here ;-)
But it is a verifiable fact that the efficiency of a class AB amp is about 50%, class D amps can get up to 90%, and class A is about 25-50% efficient. Class AB and D only draw the power that they need for a certain output level. Class A always uses it max power, even if you only need 1 watt to the speakers, and all unneeded power will be dissipated as heat.
The AVI you say can very well be using only 40 watts of electrical power when listening at "normal domestic levels", but it'll never put out those 325watts if they didn't install a power supply that can deliver the needed electrical power.
I'm sure that the Luxman's poweramp "can" deliver 100x2 watts, IF it would have a powersupply that is strong enough. 210 or 250watts will not get anywhere near that kind of continuous power(did you see what was noted next to the draw in the spec sheet?).
And every company uses different ways of getting to their acclaimed power ratings. Onkyo measures it when only one channel is driven, Denon measures two channels, but changes the THD when giving specs for driving 4ohm speakers, NAD measures a minimal power when all channels are driven, other brands only give a peak power output,...
Why? The more watts an amp has, the better it sells.
To the OP,
You might want to check some more amps in that price range. Harman Kardon has a nice one, Nad, Naim, Rotel,... All great sounding amps.
