harveymt:Is there much difference between Windows back-up and an actual program like Acronis? In the event of a computer failure I presume I'll still have to re-install everything, it won't put all the programs back installed and ready to go? Or will it? If I just cut and paste i could end up missing stuff and end up having to download a load of stuff again.
Acronis TrueImage is the one I use (although the one linked is a new version to what I have) - it'll actually image the hard disk (say to a USB drive) and allow you to create a boot disk so that, if you need to, you can boot from the boot disk and then re-image the machine from the backup. In this way, Windows, and all your programs will be back exactly as they were from the last backup, so there's no need to reinstall everything again.
al7478:Were you refering to xp with that backup facility proff, as i cant find it?
In XP, the Windows backup program is on Start > Accessories > System Tools > Backup. However, that isn't an imaging backup program like the Acronis one, so although it will backup your data, if you needed to recover, you would need to reinstall Windows, then all the programs and then restore the data from the backup. However, it is free!
harveymt:Just while I have you guys here. My mate is going down this route too. He's in the process of getting a Samsung B650 which is DLNA cert. With a DLNA-cert NAS could he stream tunes to his TV? Would the TV have a media server installed on it that will play his music or does he need iTunes running on something separate?
Looking at the Samsung B650 series, it has something called Samsung's Media 2.0 suite so he should be able to access any music he has on a NAS through this assuming it's in a supported format (from what I can see in the manual, it only supports MP3).
