Question Great looking speaker cables with almost no margin
AJM1981
695
258
5,270
I don't believe in sound properties when it comes to cables but I maybe would like a thicker cable then I currently have for no other reasons than improve the setup slightly visually and perhaps to avoid that by any force the plugs come off. Given this, I would not like to spend anything more on it than a reasonable price.
Is there anything for non-believers on the market that lacks an insane virtual margin and is just decent?
The “go to” anti-brand for speaker cable seems to be Van Damme. I’ve never used it, but it get’s mentioned a lot on forums. You could investigate that.
Thanks, also these ones seem decent. The price is 45 euros for 3 meters.
found the one below (2.5m) in an online outlet for 50 Euros. Originally 225 euro's (which adds 175 euros for the color purple if the new cable above is a reference)
I buy KabelDirekt from Amazon the 4mm for long runs and the 2.5mm for normal runs terminate it with fiscal banana plugs I think it looks good, its a clear jacket so you see the copper so it depends if you like that look.
Reactions: Gray and AJM1981
Those QED ones seem reasonably priced.
But for maximum value the above suggestions are good.
Some Van Damne OFC by the metre and fit your own plugs. I too can recommend the Fisual ones.
Apart from an ignorable naff logo on the plastic case, they're good quality with easy, 2-screw fixing.
Reactions: Al ears and AJM1981
