Greasing a turntable ?
kitkat
162
I have a Pro-ject Debut SB and came across by chance on the internet some special grease made for turntables, can anyone advice me if I should grease my turntable, and if so where abouts. Thanks.
This is actually in my collection
Here is the recommended Pro-Ject grease...
http://www.project-audio.com/main.php?prod=greaseit&cat=accessories&lang=en
It would be used for the main bearing.
What makes you think your turntable bearing needs lubricating? (Apart from finding a product, "by chance on the internet", and getting anxious that you might need it.)
