Grado’s rich heritage shines through these wired and wonderfully transparent open-back headphones.
Grado SR80x : Read more
Hasn’t that been the case ever since the 80 and 325 were available? For my limited use, I find the earlier SR80e to be great, and the quirky design is appealing too.It begs the question:
With the SR80x being so good, are the SR325x worth more than double the price tags? Even more if you're also going to get new earpads with the latter.
Are we getting only metal casing, or significantly better sound with the SR325x?
There are some headphone experts who contribute here, but you should look through the WHF reviews for some pointers.Which brings the question, are there any good closed headphones that are as comfortable on the long run, and performant, as opened ones ?
...like a vice!I’m old enough to remember the old Koss ‘head crushers’ from the 1970s.
I’ve had the 325x since just after launch, combined with the Zen DAC V2. Compared with cheaper headphones, up to £250, direct from my phone, I really don’t notice a significant difference, even with hi-res files. I was expecting something special but am decidedly underwhelmed. For anyone on the fence I honestly wouldn’t recommend either. I do like the soundstage due to the fact they’re open back, but the comfort isn’t great with the new pads.It begs the question:
Thank you for this valuable feedback.I’ve had the 325x since just after launch, combined with the Zen DAC V2. Compared with cheaper headphones, up to £250, direct from my phone, I really don’t notice a significant difference, even with hi-res files. I was expecting something special but am decidedly underwhelmed. For anyone on the fence I honestly wouldn’t recommend either. I do like the soundstage due to the fact they’re open back, but the comfort isn’t great with the new pads.
Comfort has never been a Grado strongpoint, one hour of use is generally all I can takebut the comfort isn’t great with the new pads.
