bigboss
Moderator
YesThese end bits seem pretty solid on this amp the bannana plugs do go in right?
If you connect the amp to the TV and select the correct HDMI, you should see the menu on the screen.I can’t get the amp to talk to the TV to do the initial setup?
which HDMI?If you connect the amp to the TV and select the correct HDMI, you should see the menu on the screen.
Surely the thing came with an instruction manual didn't it?How do you get the TV
which HDMI?
You need to select the correct number of speakers you have at the beginning of the setup.Ok I am on the speaker setup bit and it keeps trying to connect 4 surround speakers? Whereas I only have 2 and it doesn‘t understand that!
Get two more.... 🙂Ok I am on the speaker setup bit and it keeps trying to connect 4 surround speakers? Whereas I only have 2 and it doesn‘t understand that!
BB how do I check that the system is selected the speakers to small?She is working! Cheers guys!
Sorted.BB how do I check that the system is selected the speakers to small?
on Bluetooth I am only getting sound out of the front three?
That ARC thing was weird I didn’t use that on my Pioneer 81. Thanks for that.Surely the thing came with an instruction manual didn't it?
I'd use the one marked Monitor ARC
Pioneer 81 does not have ARC.That ARC thing was weird I didn’t use that on my Pioneer 81. Thanks for that.
He might help you get the best sound out of it...I’d consider rebooking it if it’s not too expensive...Cancelled Monday‘s installation he wasn’t too happy.
He's already stated it was going to cost £180, I am still trying to work out why this amp if he only has two surround speakers..... 🙂He might help you get the best sound out of it...I’d consider rebooking it if it’s not too expensive...
Oh really I missed that. Yes I think he has a 5.1 system. B&W FPM speakers and PV1 sub.He's already stated it was going to cost £180, I am still trying to work out why this amp if he only has two surround speakers..... 🙂
That was stereo for Bluetooth I got it in surround sound now.He's already stated it was going to cost £180, I am still trying to work out why this amp if he only has two surround speakers..... 🙂
Nope, it’s a keeper as long as it keeps working right.Pioneer 81 does not have ARC.
How long can you see yourself keeping the amp for? My prediction is returned on Monday!😉
😀 At the beginning when I was setup the speakers to do the setup it kept wanting to do four rear speakers whereas I only have 2 - got there in the end tho.He's already stated it was going to cost £180, I am still trying to work out why this amp if he only has two surround speakers..... 🙂
Here is the online manual ........http://manuals.denon.com/AVRX6500H/NA/EN/index.php😀 At the beginning when I was setup the speakers to do the setup it kept wanting to do four rear speakers whereas I only have 2 - got there in the end tho.
Huh?Here is the online manual ........http://manuals.denon.com/AVRX6500H/NA/EN/index.php
Your speakers should be using hardwired connection not Bluetooth and how many speakers are you using ?
As you need to connect to the red section on the back of the Av for left and right stereo connectionView attachment 1458
You was having trouble setting up your new Av amplifier up with speaker connection ?Huh?
No mate not me.You was having trouble setting up your new Av amplifier up with speaker connection ?
You have a
Denon 6500 amp
