Getting Broadband to my Blueray Player
HI
I just gotten a Panasonic 37" Freesat Tv & EBD60 Bluray player they both have an Ethernet socket fitted for broadband connection. My problem is that the broadband comes into the house upstairs and at the other side of the house, we do have a Netgear WGT 624 wireless router is there some way of using this as running a lead all the way around the house is not an option
I'd avoid the home plugs if I were you, bit noisy on the mains. An airport express is an alternative as a wireless access point, but if you want to plug in both you'll need an extender with more than one ethernet port - amazon does this one, for example.
JohnDuncan:I'd avoid the home plugs if I were you, bit noisy on the mains. An airport express is an alternative as a wireless access point, but if you want to plug in both you'll need an extender with more than one ethernet port - amazon does this one, for example.
The Belkin one doesn't work with Windows Vista or Windows 7. I had to return mine.
This is an excellent option.
